1999 Ford Ranger Wiring Diagram
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
KANDREWS
I have a 1999 4WD Ford Ranger that when the headlights are on the drivers side blinker will not work. When the headlights are not on it works fine. I have also noticed the radio display blinks when the headlights are on and I try to use the blinker. On occasion the door ajar indicator stays on along with the dome light when the doors are closed. It sounds to me that it is a wiring/ground problem. Is there anywhere you can get a wiring diagram free?
Feb 26, 2008 at 3:48 AM
LEGITIMATE007
  • 5,121 POSTS
hello i sent you some wiring diagrams to your email . hope it helps you.
Feb 26, 2008 at 7:02 AM
