1999 Ford Ranger Will not run smooth while accelerating
MACRAI
  • 1999 FORD RANGER
  • 6 CYL
  • 120,348 MILES
How do I test the fuel pump?
I replaced the Battery and the altenator.
Another problem I'm having is it is not shifting when it should.
I do not drive it during the winter and it sits outside.
I have not been able to use it all this summer because of constant problems!
Sunday, September 14th, 2008 AT 11:40 AM
Find the test port on the fuel rail if none T-in into the fuel pressure line to check fuel pressure and comeback with the readings. Also check the vehicle speed and throttle position sensors.
Sunday, September 14th, 2008 AT 2:00 PM
