1999 Ford Ranger warning chimes
1999 FORD RANGER
150,000 MILES • 4 CYL • 2WD • MANUAL
DWAYNARD
I HAVE A 99 FORD RANGER. ABOUT 3 OR 4 DAYS AGO IT STARTED BEEPING LIKE A WARNING SIGNAL OF SOME KIND. IT BEEPS FOR 4 OR 5 TIMES THEN SHORT PAUSE THEN BEEPS AGAIN. IT DOES THIS ABOUT 3 TIMES THEN QUITS FOR A FEW MINUTES AND THEN STARTS THE CYCLE OVER AGAIN. THE TONE IS LOWER THAN THE WARNING FOR THE LIGHTS FOR EXAMPLE. IT ALSO DOES THIS WHEN JUST THE IGNITION SWITCH IS ON. WHAT COULD BE THE PROBLEM AND FIX FOR IT.
Apr 11, 2009 at 5:43 PM
MERLIN2021
  • 17,250 POSTS
Seat belt warning? Maybe a bad sensor for the belt system. Scan for "B" codes.
Apr 12, 2009 at 12:02 AM
