1999 Ford Ranger Vibration when exhilarating
1999 FORD RANGER
224,000 MILES • 6 CYL • 4WD • AUTOMATIC
HUGHSTON
My Ranger will vibrate from 0 - 40 mph. The vibration is less noisy after 40 mph area. Checked the front end on a hoist. There is some "play" on the wheels when steering wheel held firmly. Will replacing the steering column resolve the vibration ?
How safe is driving the truck prior to part replacement ?
Thanks -
Jan 20, 2009 at 10:22 AM
RANGERDANGER17
  • 224 POSTS
check the universal joints in the drive shaft before replacing the steering column then check the ball joints and tie rod ends it is probable the u joints but check the others to its fine to drive
Jan 20, 2009 at 5:00 PM
