1999 Ford Ranger THUMPING NOIES DURRING COLD SEASON WHEN HE
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOHN LANGFORD
DURING THE COOLER MONTHS WHEN THE HEATER IS IN USE I GET A THUMPIMG NOIES IN THE COOLING SYSTEM I CAN PUT MY HAND ON THE RADIATOR HOSE AN IT WILL BE THOBBING WHILE ITS MAKEING NOIES IF I TURN OFF THE HEATER THE NOISE WILL NOT HAPPEN I HAD A MECHANIC CHECK FOR HEAD GASKET LEAK HE SAID CHECK OUT OK CAN YOU HELP
Feb 11, 2008 at 8:10 AM
98RANGERXLT
  • 301 POSTS
Your blend door is stuck and trying to open.
Feb 11, 2008 at 11:31 AM
