1999 Ford Ranger SuperCab 4X4
PGBURDA
  • 1999 FORD RANGER
140000 miles, AC works but I notice that the compressor continually cuts in and out. Is it low on refrigerant and what should the pressures be? Thanks.
Tuesday, May 22nd, 2007 AT 10:51 PM
PGBURDA
  • 5 POSTS
Thanks for the reply, I will check it ASAP. I assume it uses R134A.
Perry
Wednesday, May 23rd, 2007 AT 12:29 AM
PGBURDA
  • 5 POSTS
Please one more question since your on a roll. The switch for the AC/MAX AC doesnt't seem to make a difference. If I select Max AC usually all outside air is cut off, but I don't hear any difference in using Max A/C. Is the switch bad or is there a fuse or relay that is bad. Thanks.
Wednesday, May 23rd, 2007 AT 12:55 AM
PGBURDA
  • 5 POSTS
Gosh thanks so much for your quick response. I think I will make a donation now. You been more than helpful.
Wednesday, May 23rd, 2007 AT 2:22 AM
