1999 Ford Ranger Starting problems
99BADSINGERS
Engine Mechanical problem
1999 Ford Ranger 6 cyl Four Wheel Drive Automatic 115k miles
Sirs; My pickup will not start when raining, snowing, or cold from sitting outside over night. A mechanic thought it was the ??cam or crank?? sensor. He replaced it and 2 days later its doing the same thing. There is no service engine light and these guys are lost. Any ideas for me?
Regards
Oct 30, 2009 at 6:08 AM
  • 75,988 POSTS
Do below might lead you somewhere
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Oct 30, 2009 at 6:11 AM
