Do you have to remove the exhaust manifold to remove the automatic transmission in order to remove it?
Feb 25, 2010 at 12:51 AM
MIKE H R
MEMBER
You don't have to remove the exhaust mainfold to take the transmission out. It helps to disconnect the exhaust. That way you can move it so you have more room to remove the transmission and transfer case
