my oil press bounces all over when warmed up at idle i was thinking faulty sending unit . where can i locate this
Aug 17, 2008 at 3:38 AM
BLACKOP555
✓Experienced Mechanic
right near the oil filter is wehre it shall be located. i dont know if its the sending unit thats bad, make sure the wiring connector is tight and not corroded or oiled up. if that dont work check the oil pressure also.
