1999 Ford Ranger Oil
200,000 MILES • 4 CYL • 2WD • MANUAL
PAPAAL
Oil and smoke are coming out of the dipstick hole. I have replaced the PCV valve and checked the hoses. There are no leaks evident. Engine seems to be running good. Also noticed oil in the exhaust pipe.
Dec 27, 2007 at 5:49 AM
  • 31,937 POSTS
At 200,00 mls this engine is getting a bit tired, this is blow by from the combustion chambers entering the sump through worn or broken rings, no to much you can do apart from a re build.
Mark (mhpautos)
Dec 27, 2007 at 9:55 AM
