1999 Ford Ranger Noise no one can identify!!! HELP!!!!
44,000 MILES • 6 CYL • FWD • AUTOMATIC
POSEIDON_92
  • 7 POSTS
This noise just started...whenever I turn my steering wheel to the left while driving the front driver's side wheel makes a squeaky noise (kinda like then noise a tire makes when you move it on cement when you're not driving)...I've replaced the front driver's side tire after 3 different mechanics looked at everything possible--I'm at a loss and it's driving me crazy!
Nov 19, 2009 at 1:33 PM
  • 110,248 POSTS
If everything is tight, chances are it is a dry ball joint. If they are original, they are seald and can't be greased.
Dec 1, 2009 at 11:56 PM
POSEIDON_92
  • 7 POSTS
Yep took it to my favorite guys---ball joints! they are replacing all of them plus an alignment for $800. I called around and pretty much got the same price from everyone, so just gonna use the guys I trust and know it will be done right!
Thanks for you help!!!
Feb 8, 2010 at 4:48 AM
