1999 Ford Ranger Noise no one can identify! HELP!
POSEIDON_92
  • 1999 FORD RANGER
  • 6 CYL
  • FWD
  • 44,000 MILES
This noise just started. Whenever I turn my steering wheel to the left while driving the front driver's side wheel makes a squeaky noise (kinda like then noise a tire makes when you move it on cement when you're not driving).I've replaced the front driver's side tire after 3 different mechanics looked at everything possible--I'm at a loss and it's driving me crazy!
Thursday, November 19th, 2009 AT 9:33 PM
  • 109,885 POSTS
If everything is tight, chances are it is a dry ball joint. If they are original, they are seald and can't be greased.
Wednesday, December 2nd, 2009 AT 7:56 AM
POSEIDON_92
  • 7 POSTS
Yep took it to my favorite guys---ball joints! They are replacing all of them plus an alignment for $800. I called around and pretty much got the same price from everyone, so just gonna use the guys I trust and know it will be done right!
Thanks for you help!
Monday, February 8th, 2010 AT 12:48 PM
