1999 Ford Ranger no power to rear wheels
180,000 MILES • 6 CYL • 4WD • MANUAL
HARDAKERK
I have a 1999 ford ranger, 4wd manual. i just put a new transmission, clutch, slave, etc in... i completed the project just fine, everything is connected and correct... I backed it outta the garage and it was driving just fine, but then i realized that it was in four wheel drive... when i pulled over and took it out of 4wd, i had no power to the rear end when I went to take off and thus I went nowhere. changing back to 4wd from 2 it drove again... it only drives as long as the front tires are pulling it along... when i am driving i hear a clunking from the rear of the vehicle, and i havent been able to see where its coming from. is my transfer case junk or is it the rear end? thats all thats left to replace lol
Jun 6, 2010 at 1:06 PM
  • 31,937 POSTS
Hi there,
I would be thinking a diff, while you are in the car start and place in 1st gear 2WD get a helper to watch the tail shaft DO NOT GET UNDER THE CAR, if the tail shaft is turning with the transmission, the diff or a broken axle will be the problem.
mark (mhpautos)
Jun 6, 2010 at 11:57 PM
