1999 Ford Ranger misses
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
SDMEYER
the engine has a miss could it be an injector
Oct 15, 2009 at 7:42 AM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Oct 15, 2009 at 8:01 AM
