1999 Ford Ranger MAF Sensor
78,000 MILES • 4 CYL • 2WD • AUTOMATIC
NATENICKNO
Just bought the truck a week ago, was checking oil and noticed the MAF sensor was unpluged. Mind you the truck seemed to run OK. I went from a f150 v8 to the 4 cyl. for fuel economy. Anyway I pugged it back in and tried to start the struck, it started but ran poorly. I unplugged it and it ran like it did before. So I thought I would clean the sensor. I puchaced a can of sensor cleaner at the parts store and followed the directions on the can. This did nothing, If I pug it in it runs poorly or not at all. Isd the sensor bad or do I have a wiring problem to the sensor? I can use a multimeter but what should I check for?
Sep 6, 2008 at 2:21 AM
SERVICE WRITER
  • 9,123 POSTS
The Check engine light should have been on. Short of a visual check, you need a hand held diagnostic computer to check the MAF. IT probably is bad and isn't cheap either.
Sep 6, 2008 at 2:38 AM
MERLIN2021
  • 17,250 POSTS
The other point is if the wires were shorted, it would run bad even unplugged. PCM is using a set midpoint value when unplugged. Online between 125.00 and 85.00.
https://images.2carpros.com/forum/automotive_pictures/62217_MAFFORD2_1.jpg
Sep 6, 2008 at 3:00 AM
