All at once my brake lights don't work
JACKSOG0
  • 1999 FORD RANGER
  • 4 CYL
  • 4WD
  • 140,000 MILES
All at once my brake lights don't work correctly when I tap on them only when I press the pedal hard. All the lights work just don't seam to work correctly. Any solutions that might cause this.
Tuesday, October 12th, 2010 AT 2:42 PM
JDL
  • 16,098 POSTS
Is there any adjustment on the brake switch? Maybe a faulty brake switch?
This guide will help fix it
https://www.2carpros.com/articles/brake-lights-not-working
Wednesday, June 2nd, 2021 AT 1:08 PM
JACKSOG0
Where would this switch be located and if bad how can I check this?
JDL
  • 16,098 POSTS
It's a brake pedal position switch. When the switch is activated, the lite green wire goes hot and carries voltage to brake lites. Where applicable check for any adjustment.
https://www.2carpros.com/forum/automotive_pictures/170934_ranger_brake_pedal_position_switch_1.jpg
