1999 Ford Ranger Ignition coil
82,000 MILES • 6 CYL • 4WD • AUTOMATIC
TOMK_1
No spark from no. 2 tower. replaced plug and wire. All others spark. Could this be the coil or something before the coil ? Only trouble code is P03002.
Apr 3, 2009 at 1:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Most likely the coil pack is faulty. Test for spark at the coils and post results. I will follow up.
Thanks for using 2CarPros.com!
Apr 3, 2009 at 2:09 PM
TOMK_1
There are no coils on the plugs. Just a black box on top of the engine where the distributor cap should be. I assumed this was the coil.
I checked no.2 plug wire and found it was open. I used an inductive timing light ( Iv'e had it in my shed for about twenty years. Knew I'd get to use it again.) to check for spark on the plug wires and they all fired but no. 2.
Thanks for your help.
Apr 3, 2009 at 2:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You may want to check compression in that cylinder but most likely it is a faulty ignition coil.
Apr 4, 2009 at 5:07 PM
