1999 Ford Ranger Fuel System Problem?
SINGSTREAM
  • 1999 FORD RANGER
  • 4 CYL
  • 141,000 MILES
I pulled over to check out directions, but could not start my truck up again. No warning lights came on. The electrical system seems to be working fine. The engine will turn over, but will not start. Is this a fuel system problem?Today I replaced the in-line fuel filter, but that did not seem to fix the problem. (On a side note the alternator and battery were replaced 3 months ago)
Wednesday, October 28th, 2009 AT 4:33 PM
  • 109,936 POSTS
Have you checked to see if the engine is getting spark and fuel to the engine?
Tuesday, March 2nd, 2021 AT 12:07 PM
SINGSTREAM
How do I do this?
I know how to check for spark using a light pen. How do I check for fuel?
  • 109,936 POSTS
Here is a how to video and directions:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know if it helps. You will need a gauge. Most parts stores will lend or rent one to you.
