1999 Ford Ranger engine running rough
157,000 MILES • 6 CYL • 2WD • MANUAL
DDEGRAAD
engine takes a little while to start and is running rough, after a cold start tends to want to stall, some times loses power. I have changed plugs and wires. could my problem be injecters or fuel filter
Sep 1, 2009 at 4:20 AM
BIGLOGHAULER1
I also have a 1999 ranger that runs rough and looses power, bucks when you take your foot off the gas. I changed spark plugs, wires, fuel filter, flexible fuel sensor. The ford shop checked it out and told me it could be the max air flow sensor by the air filter. They told me it would give them a starting place. Thats the first thing I thought of changing after plugs. The cost of finding the problem is getting so expensive I thought of using it for a boat anchor.
Sep 2, 2009 at 6:03 PM
