1999 Ford Ranger Engine cranks, but won't start
180,000 MILES • 6 CYL • 2WD • MANUAL
DRHAMVAY
I hear the fuel pump, when ignition is on. Fuel squirts out of Schrader valve pretty good. Coil has good resistance.
The engine seems to want to start a little more when I give it some gas while cranking.
Could this still be a problem with the fuel pump, or is it something else?
Nov 10, 2009 at 6:51 AM
  • 110,248 POSTS
Yes, it could be a fuel pump or filter problem. Have you checked the fuel pump pressure? Also, are you getting spark? Will the truck start with starting fluid?
LEt me know.
Dec 2, 2009 at 8:56 AM
