1999 Ford Ranger engine
1999 FORD RANGER
44,000 MILES • 6 CYL • 2WD • AUTOMATIC
TSV
i have to replace the oil pump in my ranger, i am doing it in my drive way, with the engine in the truck, i have removed the transmission ,and the top of the oilpan is hitting the flywheel when i try to remove it, i need to remove the flywheel but the 8 bolts on it look like torx head bits, do you know what size these are so i can buy just the torx socket i need instead of a full set ?
Feb 27, 2010 at 5:36 AM
  • 110,244 POSTS
Is it a torx? If it is, chances are it is around a t-45, but honestly, I've never seen them use torx to install a flywheel.
Mar 1, 2010 at 3:42 AM
