1999 Ford Ranger Driver side door chime
ALPHALAWS
Electrical problem
1999 Ford Ranger 6 cyl Four Wheel Drive Automatic
My driver side door is open the door chime rings even after the key is out and nothing left on. Is the a switch broken or way to disconnect?
Nov 23, 2008 at 11:59 PM
DAVE H
  • 13,383 POSTS
the chimes are controlled by the GEM (generic electric module) it may be the switch is faulty replace/repair wiring on switch on rear of door .. you could disconnect the wire to isolate from the system
Nov 24, 2008 at 9:54 PM
