1999 Ford Ranger Coolant in Oil
210,000 MILES • 4 CYL • 4WD • AUTOMATIC
VICKIAF50
I am getting coolant in my oil. There is no leakage to the ground. What could be possible problem that will cause this. I am NOT getting oil in the coolant
Apr 1, 2008 at 12:02 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like a possible head gasket or cylinder head problem. Pressure test the coolaning system with the plugs out. After a half hour crank the engine with the plugs out and see if coolant shoots out any of the plugs holes.
Apr 1, 2008 at 12:31 PM
