1999 Ford Ranger clutch
120,000 MILES • 6 CYL • 2WD • MANUAL
FORDFAMILY1
How do I adj the clutch on my 99 ranger.Manual trans
Oct 26, 2010 at 8:23 PM
WRENCHTECH
  • 20,760 POSTS
You don't. It's hydraulic and non adjustable. If you are losing your pedal then you likely have a leak in either the master cylinder or the slave cylinder and it would have to be replaced and the system bled out.
Oct 27, 2010 at 12:05 AM
