Does this model have a self adjusting clutch
227,000 MILES • 4 CYL • 2WD • MANUAL
PETE CLANTON
does this model have a self adjusting clutch. i was told you could back up letting out on pedal repeatedly to adjust.
Jun 3, 2010 at 2:35 AM
This is a self-adjusting clutch system because it is a hydraulic clutch. So, it will automatically adjust to compensate for wear on the clutch disc.
I assume you are having clutch issues so here is a guide that will help with figuring out what the possible causes are.
https://www.2carpros.com/articles/clutch-symptoms
and
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Also, I am attaching the info below on this system which will give the detail about how it is not adjustable.
Please let us know what other info is needed and we can go from there. Thanks
Oct 26, 2021 at 1:19 PM
