1999 Ford Ranger changing altenator
KMB
  • 1999 FORD RANGER
  • 6 CYL
  • MANUAL
  • 160,000 MILES
How do I loosen the serpitine belt to change the altenator?
Tuesday, March 10th, 2009 AT 5:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
To remove a drive belt, simply loosen the accessory being driven (in this case the alternator) and move it on its pivot point to free the belt. Then, remove the belt. If an idler pulley is used, it is often necessary, only, to loosen the idler pulley to provide enough slack to slip the belt from the pulley.
Thanks for using 2CarPros. Com!
Tuesday, March 10th, 2009 AT 5:45 PM
