1999 Ford Ranger Brake caliper pins
151,000 MILES • 6 CYL • 2WD • AUTOMATIC
CUTFORTH12
My repair manual has a statment that the lubrication on the pins is a special lubrication. Is this true and what do we use for replacement. Should the rubber boot be replaced also? Thanks for your time. I am looking forward to your help.
Mar 12, 2008 at 2:24 AM
BLACKOP555
  • 10,386 POSTS
you can use brake caliper grease, the boots should be replaced if they are cracked and dry rotted.
Mar 12, 2008 at 2:15 PM
