1999 Ford Ranger Auto locking Hubs for 4x4
117,000 MILES • 6 CYL • 4WD • AUTOMATIC
JCAV856
My 4 wheel drive isnt working but my transfer case is. I hear a clicking noise when i put it into 4wheel high but front tires dont spin then i put it in 4wheel low and the gears change but still no front tires. Is this my auto hubs? if so can i change so manul hubs and how much will that cost?
Feb 24, 2008 at 9:09 AM
BLACKOP555
  • 10,386 POSTS
check to see if your front drive shaft is turning. let me know what you find.
Feb 24, 2008 at 10:54 AM
WILEBILL89
I am having the same problem and my axle shafts are turning but the hubs are not engaging. So you have a source for locking hubs for this vehicle?
Oct 24, 2008 at 1:51 AM
BLACKOP555
  • 10,386 POSTS
automatic or manual locking hubs?
year, manufacture, model of vehicle
engine size?
Oct 24, 2008 at 3:43 PM
WILEBILL89
1999 Mazda B4000 V-6 4.0 has vacuum hubs now that do not work and would like to switch to manual hubs, the current hubs have a type of plastic clip that holds them on.
Oct 26, 2008 at 11:37 PM
BLACKOP555
  • 10,386 POSTS
you want to swtich from auto hubs to manual?
if thats the case you shoudl be able to pick up a conversion kit to stick in its place. not too hard to do.
would you like a diagram of manual or auto hubs?
Oct 27, 2008 at 1:14 PM
SCOOTDOGYDOG
I have the same problem, except my drive shaft does not turn. What might the problem be in that case?
Nov 19, 2008 at 7:20 AM
BLACKOP555
  • 10,386 POSTS
manual or auto hubs? does the 4x4 indicator light up?
Nov 19, 2008 at 11:02 AM
SCOOTDOGYDOG
Auto Hubs, and Yes, the indicator lights up and stays lit.
Thanks!
Nov 19, 2008 at 11:50 AM
BLACKOP555
  • 10,386 POSTS
may be an issue with the actuator then. youll just have to check it for damage if you turn the front shaft by hand, where it leaves the transfercase does it keep spinning or does it go and stop>?
Nov 19, 2008 at 9:12 PM
