1999 Ford Ranger ABS light and BRAKE light
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
MAKIKUN
I have a 99 ranger 2wd 3.0L V6. Today my ABS light as well as my BRAKE light came on. They stay on all the time. I made sure the e-brake wasn't stuck on. Also my battery light keeps blinking off and on. I replaced the battery, the voltage from the alternator is good. Is this a grouding issue? If so, where is the ground cable? When I restart the car, the ABS and BRAKE light come on right away and the battery light blinks off and on randomly.
Apr 18, 2008 at 7:13 PM
BMRFIXIT
  • 19,053 POSTS
have the charging system tested
you can scan for codes too
you may end up needing an alternator
check brake fluild if low check brakes
Apr 18, 2008 at 11:02 PM
MAKIKUN
i checked my brake fluid. it was low. filled and now working fine! w00t
Apr 21, 2008 at 2:18 PM
BMRFIXIT
  • 19,053 POSTS
all OK
you should check the brakes ASAP
low fluid is a sgin that you are going to need brake job soon
GOOD LUCK
Apr 21, 2008 at 10:28 PM
