1999 Ford Ranger
COGFIGCOG
  • 1999 FORD RANGER
1999 Ford Ranger 6 cyl Four Wheel Drive Automatic
How do you change the cruse control switch? I assume the steering wheel center cover needs to come off but how is this done?
RC
Wednesday, October 21st, 2009 AT 9:47 AM
  • 109,747 POSTS
The steering wheel needs to come off, but you have an airbag to deal with. Make sure the battery is disconnected for at least an hour. Once you remove the center section of the steering wheel, there is a bolt that will need removed and then you will need a puller to get the steering wheel off.
Tuesday, October 27th, 2009 AT 10:52 AM
