1999 Ford Ranger Heater Core Leak
OCEANSIDEG
i have a 1999 ford ranger that i had to do the heater core on and the heater core is still leaking. i am a tech at a shop and this is the 4th heater core in there. I had an aftermarket one put in first, then a second and then i realized that maybe it had to be a ford part. So, i put on a ford motorcraft heater core on it and it went bad too. It leaks and i dont know why it keeps on taking down heater cores down. If you can please help, or tell me some tips on this i would appreciate it. Thanks.
Apr 12, 2007 at 8:11 AM
MERLIN2021
  • 17,250 POSTS
Do you use the right coolant? Flushed the system? Maybe changed the hoses? They can split inside and not tighten properly. then when the pressure builds to 16lbs, it will spray into the core area! Next time it happens, take the core to a radiator shop and pressure test it.
Apr 12, 2007 at 8:53 AM
Suggested Repair
Use the correct coolant, flush the cooling system, and inspect the heater hoses for internal splits that prevent a proper seal. Have a radiator shop pressure-test the failed heater core.
Conversation Summary
The owner of a 1999 Ford Ranger reports repeated heater-core leaks after four replacements, including aftermarket and Motorcraft units. The expert suggests checking the coolant, flushing the system, inspecting hoses that may split internally and fail to seal under pressure, and pressure-testing the failed core at a radiator shop.
