1998 V6 INTAKE MANIFOLD
JIMVANDYUSA
I HAVE A 1998 FORD RANGER 4X4,V6. I HAD ONE OF THE METAL TUBES ON THE TOP OF THE INTAKE MANIFOLD BREAK OFF. THERE ARE TWO TUBES. THEY HAVE WATER LINES COMING FROM THE HEATER HOSES. I GUESS IT IS FOR CIRCULATING WATER THROUGH THE MANIFOLD. MY PROBLEM IS I DON'T KNOW HOW TO FIX THE PROBLEM. IT LOOKS LIKE THE TUBES WERE PRESSED FITTED INTO THE ALUMINUM MANIFOLD. I NEED SOME HELP.
Sep 29, 2007 at 4:27 PM
MERLIN2021
  • 17,250 POSTS
At this point you may need to drill and tap, then screw in a piece of tubing! Connect with ruber tube and clamps, don't forget the teflon thread sealer!
Sep 30, 2007 at 12:47 AM
