1998 Ford Ranger Will not cool
STALLIONPLAYBOY
  • 1998 FORD RANGER
Air Conditioning problem
1998 Ford Ranger 4 cyl Two Wheel Drive Automatic
I have had my air conditioning recharged multiple times and yet it still loses cooling capablilities.I have had it checked for leaks and none appear. What can I do?
Sunday, June 1st, 2008 AT 4:31 AM
BMRFIXIT
  • 19,053 POSTS
The system should be 100% seal proof
and if you keep add to it then its leaking and you need to find the leak
you should have it check by qualified tech
( they can add special DYE to the system and check it for leak )
Sunday, June 1st, 2008 AT 7:47 AM
98RANGERXLT
  • 301 POSTS
Look arund the a/c compressor/clutch does it look oily?
Monday, June 2nd, 2008 AT 8:16 PM
