1998 Ford Ranger What keeps causing a Error Code P0303 in a
DISCODAZZ1
Engine Performance problem
1998 Ford Ranger 4 cyl Two Wheel Drive Manual
I have changed the feul filter, spark plug wires, spark plugs, throttle position sensor, idle air control valve coil packs are good, and cleaned the throttle body. Need help Thanks
Nov 8, 2008 at 10:24 AM
  • 31,937 POSTS
HI there,
That is a miss fire cyl No 3... check for a vacuum leak around that cylinder and may be get the injectors serviced, start there.
mark (mhpautos)
Nov 8, 2008 at 8:04 PM
