1998 Ford Ranger what is going on?
LILLIEIII
  • 1998 FORD RANGER
  • 4 CYL
  • 185,000 MILES
My 98 ranger's ac seem to not produce effectively at low speed once I pull from complete stop seem ths once the transmissiom has shifted it doesn' want to kick back on, must rmp motor to force it to kick back on. ( Think something to do with the computor)
Sunday, August 1st, 2010 AT 6:17 PM
KHLOW2008
  • 41,814 POSTS
Hi lillieIII,
When the compressor cuts off and does not reengage, test for battery voltage at the compressor clutch wire. If power is not available, then we need to back track to the relay or computer. If power is available, then the compressor clutch is weak and does not have the power to reengage. It could be the clutch clearance is excessive.
Monday, August 2nd, 2010 AT 1:44 AM
