1997 Ford Ranger Temp Control Does Nothing
182,208 MILES • 6 CYL • 4WD • AUTOMATIC
TEDP
My sons Ranger always puts out heat no matter where the temp selector control is unless it is in MAX A/C.
Ford wants a thousand dollars to look at it.
Sep 18, 2009 at 1:43 AM
RACEFAN966
  • 5,029 POSTS
Ok this is probably the blend door or more likely the blend door motor. Here is a pic of the blend door motor. If you have a digital multi meter we can test it to make sure it is bad. These are available at most parts stores. Blend door motor
https://images.2carpros.com/forum/automotive_pictures/249564_Graphic_131.jpg
Blend door
https://images.2carpros.com/forum/automotive_pictures/249564_379286_2.jpg
Sep 18, 2009 at 2:51 AM
TEDP
Thanks...
Sep 19, 2009 at 1:15 AM
RACEFAN966
  • 5,029 POSTS
No problem let me know how things go and if you need anymore help just ask. Thanks.
Sep 19, 2009 at 2:15 AM
