1998 Ford Ranger vacuum problem?
149,000 MILES • 4 CYL • 2WD • AUTOMATIC
RBPGURU
after driving, [engine at op-temp] when accelerating engine is knocking. any suggestions? thanks.
Oct 17, 2009 at 11:58 AM
  • 75,988 POSTS
If is not an actual engine knocking coming from the bearings or the upper end could be detonating caused by the EGR valve, the Knock sensor or an engine that's overheating
Oct 17, 2009 at 12:38 PM
RBPGURU
Thanks. I am leaning towards the EGR valve. From my reading, it appears to be the most identified probable cause. I am not sure that I have a knock sensor. There is a vacuum valve solenoid operated regulator, too. I noted a while back, during the hot season, that when I selected the MAX AC setting, the inside/outside air flapper valve cycled from the vent location to the floor then back. Not sure if that indicates a common problem associated with the vacuum system. There is a vacuum reservoir [bulb shaped tank] that outputs to the cab, [heat/AC air flapper control]. Thanks, again.
Oct 23, 2009 at 1:36 PM
