Has battery been recently disconnected? If so the KAM was wiped clear and the vehicle will have to be driven to clear things up. Also have you noticed extended cranking times before the vehicle will start. If you give gas after its started up will it run good unless gas is let off, or does giving it gas cause it to hesitate and run rough until vehicle has driven a bit.
After its running good do you notice any issues with drive ability at all.
The iac may be bad and just taking a bit longer to open up if its starting to plug up. Remove it and make sure the pintle on it moves freely in and out along with no carbon being built up inside of the throttle body ports for the IAC
SPONSORED LINKS
Monday, September 27th, 2010 AT 12:06 AM
