Couple days ago did my first transmission oil and filter change , everything went right except when i did the first test trip , the transmission slips on first change when is cold, i had to hit the gas a little times before it change , add more oil and still the same, the oil level is correct , Before the oil change the transmission was good, i did the change because of the oil was burned and i bought the truck 6000 miles ago.
What can i do?
What can i do?
Mar 14, 2009 at 3:37 AM
