It went really well and then not so well. We got everything hooked back up, started the engine, and witnessed the transmission fluid squirt out the radiator line we left disconnected. We thought we nailed it! With the transmission line hooked up again, in the garage, we went through the gears and moved a few feet back and forward. We checked the fluid level. Everything was looking good. Now, as we manuevered around the driveway to go on a test drive things stopped working! The trans fluid was no longer pumping.
I'm pretty sure nothing was damaged with the first installation of the torque converter as there were no noises or bangs that usually accompany mechanical failures. And there were no such noises today either.
I read somewhere that you should be carefull if you flush older transmissions as it could dislodge debris and clog things. Even though we didn't do an official "flush" there has been a lot of turbulence in that transmission lately. Could we just have a clog somewhere?
What do I do now?
Thursday, March 11th, 2010 AT 7:23 PM
