1998 Ford Ranger throttle
31,000 MILES • 6 CYL • 2WD • MANUAL
DARYLLAGER
the throttle seems to stick but i had the cable checked and the pedal all fine? what else could be wrong something with the throttle body?
Aug 15, 2008 at 6:29 AM
BLACKOP555
  • 10,386 POSTS
most likely cause is a dirty throttle body, i would check that out first and clean it up good plates and all. after that i would check and compare the tenstion on the butterfly valve with tension on a nother vehicle.
very unlikely but possible the spring could be weakening.
Aug 15, 2008 at 10:09 AM
