1998 Ford Ranger Starting problems
124,000 MILES • 6 CYL • 4WD • MANUAL
BULLMAN
After starting my truck the engine begins to idle to 2500 rpm then down to 1000 rpm then back up again, on some of the low rpm's phases the engine will stall out. This continues for a few minutes then the Rpm's level out and everything seems fine. Any thoughts on what the problem may be?
Mar 2, 2009 at 9:40 AM
THETOOLMAN
  • 123 POSTS
Sounds like the IAC valve needs cleaning. This is mounted on the Air Intake it has two screws and
an electrical connector. This device collects carbon
this carbon build up is what cause the sluggish idle
response. Cleaning it should get you back to normal.
Mar 3, 2009 at 4:25 AM
