1998 Ford Ranger Starting issues.
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHIFTMX860
Ran the car for about 30 minutes and it ran perfectly fine, starting and all. No previous issues starting. Came out of a store and attempted to start the truck and turned the key and got one "click" and following that click the battery seemed to be drained of voltage and would not turn again (did not crank or attempt to crank over). Figured something caused the battery to drain to I tried to jump start it and it did the same thing, no cranking over and seemed to be dead immediatly afterwards. Alternator and battery are both within 4 months new.
May 6, 2010 at 3:18 AM
  • 110,251 POSTS
Have you checked to see if the battery is actually charged?
May 11, 2010 at 5:37 AM
