1998 Ford Ranger starting
190,000 MILES • 4 CYL • 2WD • MANUAL
DONZO123
i will drive shut ranger off wont start,it will roll over,let it sit for 15 minutes then it will fire up
May 2, 2009 at 9:58 PM
SERVICE WRITER
  • 9,123 POSTS
You need to test while the no start is happening. First two things I would check to see if they are adequate would be the loss of spark and the los of fuel. A spark tester will test for spark, and a fuel pressure gauge will show the true fuel pressure.
May 2, 2009 at 11:04 PM
