1998 Ford Ranger stalls/dies
ROBERT M.
  • 1998 FORD RANGER
  • 4 CYL
  • MANUAL
  • 11,200 MILES
I have a 1998 Ford Ranger with 112k miles. The truck will start, but will die after about 3 minutes. If I hold the RPM's steady It sounds ok. Also when I drive it, it has no power. As I shift from 2nd to 3rd you can really feel the lose of power. When I am going up-hill I have to shift down no matter what % the grade is. Also when I come to a stop, the engine will die before I come to a complete stop. I have replaced the fuel pump and the filter and the problem still exist. I disconnected the fuel line after the filter and I have fuel flow when I turn the key to allow the pump to pump. I removed the vaccum line from the fuel pressure regulator while the truck is running during the 3 minutes it will stay running and the truck starts dieing. When I put my finger over the vaccum connection at the manifold, I feel suction and it runs the same as if I did not disconnect the vaccum line. The pressure test valve on the fuel rail has NO pressure at all. Whether its running or not. Can this problem be the "Fuel pressure regulator"? I also should mention that there is NO check engine light on.
Monday, March 30th, 2009 AT 2:30 PM
RANGERDANGER17
  • 224 POSTS
Make sure nothing is clogged in your intake try to run it with no air filter they check all vacuum lines
it could be the regulator or it could be the what ever the vacuum line is connected to like a special valve that is supposed to open also have you thought about try to re time the engine
Monday, March 30th, 2009 AT 6:32 PM
ROBERT M.
  • 5 POSTS
Would the timing cause the pressure relief stem to read 0 psi?
Monday, March 30th, 2009 AT 8:58 PM
ROBERT M.
  • 5 POSTS
Coil packs are clean. Can some one please let me know if this problem can be caused by a bad Fuel Pressure Regulator? I dont have pressure on the fuel rail.
Tuesday, March 31st, 2009 AT 3:21 PM
RANGERDANGER17
  • 224 POSTS
A bad fuel pressure regulator will not cause you to have fuel pressure
that sounds like a fuel problem
since you do the pump and the filter there might be something stuck in your line
use compressed air to blow the lines out
Tuesday, March 31st, 2009 AT 5:43 PM
ROBERT M.
  • 5 POSTS
HELP
Tuesday, April 7th, 2009 AT 1:18 PM
ROBERT M.
  • 5 POSTS
Do I really need to donate to get some real help here?
Thursday, April 16th, 2009 AT 2:57 PM
