1998 Ford Ranger stalls when stopping
MRS. K.
  • 1998 FORD RANGER
  • 4 CYL
  • MANUAL
  • 165,923 MILES
This morning, my truck died at a stop light. It works just fine when I keep the RPMs up, but when I stop or idle, the engine dies. Is this something to do with the fuel system? Ive never had a major problem before and Im scared to even try driving it right now because I don't want to make the problem worse. Thanks.
Tuesday, December 22nd, 2009 AT 5:55 PM
  • 31,937 POSTS
Hi there, the idle speed is controlled through the ECU and an idle control motor, check for any vacuum leak and unresolved fault codes with a scan, if all ok have the idle control motor check out.
Mark (mhpautos)
Tuesday, December 22nd, 2009 AT 8:32 PM
