1998 Ford Ranger slipping
178,000 MILES • 6 CYL • 4WD • AUTOMATIC
GTDRIVER2001
i have a 98 ranger 4x4, with an automatic, the transmission slips some between 2nd and 3rd, do i have to change the transmission, or could it be the trans filter that may be the problem?
Feb 25, 2010 at 6:21 PM
  • 110,248 POSTS
IF the trans fluid is clean and full, chances are the clutches are bad and a service most likely won't help. I doesn't hurt to try, but I will say if the trans fuid is really dirty and has a burnt smell, it could make it slip worse.
Mar 1, 2010 at 8:28 AM
