Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ranger
Engine
Symptoms
Runs Rough
1998 Ford Ranger rough running
1998 FORD RANGER
194,000 MILES • 6 CYL • 2WD • AUTOMATIC
CBECKEY
MEMBER
1 POST
running rough so i replaced all spark plugs and wires and that didnt work replaced coil pack and that didnt work whats next
Jun 25, 2010 at 1:54 PM
Experienced Mechanic
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jun 25, 2010 at 9:48 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
