1998 Ford Ranger ranger p0125 code
MIKE240
Computer problem
1998 Ford Ranger 4 cyl Two Wheel Drive Automatic
have a ford ranger whit chek light on they give me this code p0125 butt i dont really understand what to do,,,Insufficient Coolant Temperature for Closed Loop Fuel Control ,,,,,,do i have to change the termostat??
Feb 10, 2010 at 4:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P0125 indicates that the engine coolant temperature (ECT) sensor has not reached normal operating temperature. Possible causes are insufficient engine warm-up time, thermostat leaking or stuck open or low coolant. Check your coolant level, if it is OK then suspect faulty thermostat.
Feb 10, 2010 at 4:51 PM
MIKE240
[quote:c1ec197cad="bluelightnin6"]DTC P0125 indicates that the engine coolant temperature (ECT) sensor has not reached normal operating temperature. Possible causes are insufficient engine warm-up time, thermostat leaking or stuck open or low coolant. Check your coolant level, if it is OK then suspect faulty thermostat.[/quote:c1ec197cad]
thanks i check it
Feb 10, 2010 at 4:59 PM
