1998 Ford Ranger Power Steering Pump replacement
1998 FORD RANGER
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
NEWELL THORNTON
Basic instructions please.
Aug 5, 2010 at 5:46 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.I need to know what is the 8th digit of your vin so i can get you the correct information.
Aug 5, 2010 at 7:23 AM
NEWELL THORNTON
the VIN is: 1FTYROU2WPA4076
Aug 5, 2010 at 7:57 AM
SATURNTECH9
  • 30,869 POSTS
So you have the 3.0L?
Aug 5, 2010 at 9:07 AM
SATURNTECH9
  • 30,869 POSTS
Engine size i mean.
Aug 5, 2010 at 9:11 AM
NEWELL THORNTON
How can I remove the power steering pump? Can I remove mtg bracket and pump together? Or do I have to pull the pullery (sheave) first?
Aug 5, 2010 at 9:57 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part4_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part5_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part6_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part7_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part8_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part9_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part10_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_ranger_3_part11_1.jpg
I asked if you had a 3.0L engine you never answered there is two different V6 engine's a 3.0L and a 4.0L I posted the instruction's for the 3.0L i hope that's what you have.It doesn't say to drain the power steering fluid out before you take it off but you will have to do that it's a lot less messy that way.You can get one of those big red balled battery filler's to drain it.
Aug 5, 2010 at 1:11 PM
NEWELL THORNTON
Louie:
Thanks so much, you supplied me with exactly the info I need to change the pump. I'll recommend your services to any who fixes their own cars...
Newell Thornton
Aug 5, 2010 at 4:54 PM
SATURNTECH9
  • 30,869 POSTS
Glad to hear that was the information you needed.We are here to help those in need with there car's.Thank's for using 2carpros.
Aug 5, 2010 at 5:34 PM
